Old 02-12-2012   #1
Shrek
Default Dyno Pull yesterday (OBX Headers)
After 2 months of thrashing on the track conversion, I finally got the car to my buddies shop for a track alighnment. While there, we strapped it down for a quick dyno pull to make sure all of the changes worked properly (OBX headers/Plenum coolant elim/Secondary vac elim)
Only had time for one quick pull, but I'm pleased with the numbers! 339.8 HP/342.2 TQ. That's compared to 309 HP/310 TQ in 2003 through the stock manifolds with Flowmaster cat back. The Flowmasters sound even better throught the headers!!!
***EDIT***OOPS.....I just went through all of my files on the car, and the first numbers were through the stock exhaust (NOT THE FLOWMASTER CAT BACK)***
Headed to VIR next weekend for her first event!
Done so far!
Vansteel coilover package
Banski spherical/heim camber rods
Banski spherical/heim toe rods
Banski spherical/heim trailing arm rods
SPC spherical/heim front upper A-arms
Exotic Muscle adjustable sway bar end links
Del-A-Lum lower A-arm bushings
Poly sway bar bushings (w/front relocation block)
DRM camber rod brackets
DRM trailing arm brackets
Carbotech pads
DRM brake bias spring
Nitto NT-01
Hurst short throw shifter
C beam plates
Elite Engineering oil catch can
Block plenum/TB coolant flow
Removed secondary vac, actuators & blades
OBX headers
Removed secodary vac system
Haibeck reprogram for secondaries & headers
DRM Chassis bar
Kirkey seats
Crow harnesses
MOMO steering wheel and adapter (2 ohm resistor for airbag light)
Shrek is offline   Reply With Quote
Old 02-12-2012   #2
Default Re: Dyno Pull yesterday (OBX Headers)
Very cool!
Love to see some video of that beast in action!
Old 02-12-2012   #3
339.8??
Curious... have you done a compression check, and if so, do you remember what it did?
30 is a good bump for headers, but seems there is more to be had at that. Could be the dyno too, I guess. Anybody else? ?
Old 02-12-2012   #4
Shrek
Wish I could say it was just the headers, but I can't!
2 different Dyno jets.
New injectors last year.
***I just went through all of my files on the car, and the first numbers were through the stock exhaust (NOT THE FLOWMASTER CAT BACK)***
Old 02-12-2012   #5
sammy
i believe the difference was compared to a totally stk exhaust . kinda tough to figure the individual improvement with all the changes that were made ,. as dominic shared in an earlier thread , one needs to chassis dyno tune the car to get the most out of ones changes . generic tunes only go so far . jmho . but 30 more hp will stiil be alot of fun
Old 02-12-2012   #6
Marc Haibeck
Road racers should be aware that water pump cavitation occurs at 6100 rpm. Engine speed over 6100 rpm for more than a few seconds can overheat the engine. I know of two LT5’s that have pushed back head gaskets at VIR.
The common scenario is the driver is busy driving and the check engine light goes on because the coolant has reached the 250 degrees F. high temperature limit. The driver becomes aware of the situation when the engine control system disables the secondary port throttles.
If the driver up shifts and runs the engine at less than 5500 rpm, the engine temperature will drop rapidly as the coolant circulation resumes. The engine temperature will usually return to a normal 210 degrees or so in about half of a lap.
The failure mechanism is that the aluminum liners expand much more than the steel head bolts. The gasket gets crushed and then fits loose after the engine cools. Normal driving eventually pushes the loose fitting gasket off the liner at the exhaust coolant passage.
Reducing the pump speed can raise the cavitation speed. A ZR-1 Products under drive water pump pulley will raise the cavitation speed to 6400 rpm. If an under drive water pump pulley is used with an ATI under drive crankshaft pulley the cavitation speed will increase to 7500 rpm. Use of the two pulleys may cause the engine to run hotter at idle with the AC on.
Old 02-12-2012   #7
Marc is there a way to ring the head....and would that help this issue??
LGAFF is online now   Reply With Quote
Old 02-12-2012   #8
mike100
Seems a little odd that the rwTQ is higher than rwhp. Mine put out around 330 rwTQ and about 350hp. That was run in 3rd gear (stock manifolds). I have heard discussions that some cars will show 5-10 hp more if you run in 4th. Then there is the individual dyno and the elevation of the test etc etc.
The one thing that does jive is that headers/exhaust are good for an easy 30 rwhp.
Old 02-12-2012   #9
Nice numbers
Old 02-12-2012   #10
Marc Haibeck
Hi Lee,
The OE gaskets work well up to 650 hp if the engine does not detonate excessively or overheat. A wire ring can help lock the OE gasket in place. However the modern solution is to use a MLS head gasket. It’s easier to install MLS gaskets than to modify the cylinder heads.
The OE gasket crushes to fit. It does not rebound much when the clamping force is increased and then reduced. A MLS gasket will spring back if it is over-clamped on a hot engine. We use MLS head gaskets on all of our assemblies.
Still the fundamental problem of overheating should be addressed directly. Head gaskets are easy to replace compared to other damage that an overheating engine might sustain.
