Old 02-12-2012   #21
rhipsher
rhipsher's Avatar
Default Re: Dyno Pull yesterday (OBX Headers)
Originally Posted by Shrek View Post
After 2 months of thrashing on the track conversion, I finally got the car to my buddies shop for a track alighnment. While there, we strapped it down for a quick dyno pull to make sure all of the changes worked properly (OBX headers/Plenum coolant elim/Secondary vac elim)
Only had time for one quick pull, but I'm pleased with the numbers! 339.8 HP/342.2 TQ. That's compared to 309 HP/310 TQ in 2003 through the stock manifolds with Flowmaster cat back. The Flowmasters sound even better throught the headers!!!
***EDIT***OOPS.....I just went through all of my files on the car, and the first numbers were through the stock exhaust (NOT THE FLOWMASTER CAT BACK)***
Headed to VIR next weekend for her first event!
Done so far!
Vansteel coilover package
Banski spherical/heim camber rods
Banski spherical/heim toe rods
Banski spherical/heim trailing arm rods
SPC spherical/heim front upper A-arms
Exotic Muscle adjustable sway bar end links
Del-A-Lum lower A-arm bushings
Poly sway bar bushings (w/front relocation block)
DRM camber rod brackets
DRM trailing arm brackets
Carbotech pads
DRM brake bias spring
Nitto NT-01
Hurst short throw shifter
C beam plates
Elite Engineering oil catch can
Block plenum/TB coolant flow
Removed secondary vac, actuators & blades
OBX headers
Removed secodary vac system
Haibeck reprogram for secondaries & headers
DRM Chassis bar
Kirkey seats
Crow harnesses
MOMO steering wheel and adapter (2 ohm resistor for airbag light)
Although Im glad to see the increase in hp do to headers and by no means want to burst any bubbles but 309rwhp tells me there's a problem somewhere. At the very least a healthy stock LT5 should put down 325rwhp. Mine put down 340rwhp 335 ft with stock manifolds and just an old Borla. Mine once dynoed at 309 only because my drivers side cat decided to expload and exit the exuast and Corey took his foot off the gas. Corey said it was actually pretty awesome. A big flame shot out the muffler and honeycomb substrait hit the wall. Lol!
