Old 11-22-2006   #11
petefias
Default Re: Brake Fluid
Originally Posted by evl_twn
I've been using this as well for years. Never lost a pedal on the track with it if it was less than 6 mos old. Once it is more than a year old it is useless. The good news is that it is cheap. This will NOT hurt your brake system.
petefias is offline   Reply With Quote
Old 11-22-2006   #12
evl_twn
evl_twn's Avatar
I've got speedbleeders on the calipers now that I've just done the brakes, so it'll be easy to do the brake fluid at least once a year, more often if it needs it.
evl_twn is offline   Reply With Quote
Old 11-22-2006   #13
bobbyhi
bobbyhi's Avatar
Thanks for all of the replies. Sounds like I will be going with the Valvoline
Syn. I think that the book says 1 quart will do for bleeding but I'll pick up a couple to be sure. Thanks again
Old 11-22-2006   #14
I have never needed more than one quart to get clean fluid coming from all four calipers.
Old 11-23-2006   #15
petefias
1 quart will be plenty, don't stock up on it, use fresh every time.
Old 11-23-2006   #16
bobbyhi
bobbyhi's Avatar
gottcha - 1 qt only - thanks...
Old 11-23-2006   #17
jonszr1
jonszr1's Avatar
hope this is ok do any of you use a power bleeder if so what type. Is there anything special to do when bleeding this car?
