Old 03-23-2012   #1
Default Starter?
I parked at my project site, had a 2hr meeting, get in the car and turn the ignition key and I hear a faint click but no starter. So, I turn the hedlights on and check the headlight - full bright. I try starting with a spare ign. key I keep in the car - the same. A faint click.
Luckly, I am parked nose up on a slight incline, so I let the car drift backwards in reverse gear w/ clutch depressed and engage the clutch and get her started. Immediately following the start I check the voltage in digital gauge and volts look normal - 12.8 to 14.1 depending on the rpm.
My conclusion is that after 18 years and 128,000 miles of service, my starter is slowly dying - your thought?
Old 03-23-2012   #2
tccrab
tccrab's Avatar
Default Re: Starter?
If you hear a "Click" and no start the problem is the most probably the starter solenoid contacts going bad.
If you've never rebuilt a solenoid before it's probably just as well to change the whole starter.
Don't rule out the clutch safety switch, it could be causing problems too.
Jumper it out first and see if starting improves.
'Crabs
Old 03-23-2012   #3
pantera1683
To check the Clutch Safety Switch (CSS):
Switch the dash display to Volts.
Turn the key to start while depressing the clutch
If you see the voltage drop as you turn the key the CSS is working.
Old 03-23-2012   #4
Thanks for the tips!
I will check CSS per suggestion.
Old 03-23-2012   #5
When CSS goes is it intermittent? Or when it goes it goes completely?
Old 03-24-2012   #6
Yun, I think the CSS is a progressive failure related to the contacts going bad. I would guess they get fried by the spike of the start amps going thru them.....but I thought the later cars had a rework of that circuit so the full starting amps never went thru the CSS any longer??? I may be wrong on that last thought!
Old 03-24-2012   #7
Progressive - meaning intermittent at the beginning and more frequent until going completely dead?
Old 03-24-2012   #8
Brad Sewell
$980 to replace the starter at the Chevvie dealer
Brad Sewell is offline   Reply With Quote
Old 03-24-2012   #9
C4Fanatic
I met a guy at the local swap meet last month that said he would rebuild the LT5 starter for me if I ever need it done.
C&P Auto Electric
815 Sunnyland
Moore, OK 73160
405-799-2083
405-799-2088
cpautoelectric@hotmail.com
Christian Chenault
Jerry is from down that way, he may have heard of this guy and have some input, I'll probably give him a try should I ever need it done.
C4Fanatic is offline   Reply With Quote
Old 03-24-2012   #10
Well, I love Mom, Chevrolet & Apple Pie, but I guess we probably won't be going there to get our starters replaced!
