Old 03-25-2012   #7
Default Re: Hi Idle 1K RPm
Don,
Absolutely it will cause a high idle. Several ways to help seal that using zip ties and sleeving the PCVs. I also have spare PVC hoses available.
Finally, check TPS voltage and Min Air Adjustment.
I agree
Purdy sheer "the Don" will need a scanner or the like to see IAC counts, in order to determine idle set screw setting. And too, if IAC counts are ZERO, then air is getting in somewhere!
Don, there should always be idle air counts; how many depends on engine temp and idle screw setting.
__
P.
