Old 03-28-2012   #17
Default Re: Stalls and Bucks
Originally Posted by dckingan View Post
Hi Tom, Dominic and Yun,
You guys are awsome. With all the warm weather in the Buffalo area I couldn't wait until I got back from Florida to install the new MAP pipe. Guess what, it was the dreaded MAP vaccum hose that I incorrectly installed just as Yun said and Tom suspected. Wow, the Z is now a pleasure to drive without the threat of an idle stall and accelerates smoothly in any gear with no bucking. I will also check out the fuel pumps and codes when I get back home. I can't thank you guys enough. Stay tuned you are now my go to guys for any future problems.
Dennis
Great! Now instead of dishing out $39.50, I went to Advance Auto Parts, bought a hard plastic hose (1/4" or 3/16") and a piece of corresponding rubber hose for connections. At the joint between the rubber hose (used as fittings) and hard plastic a dab of crazy glue to keep them together and you have a cheap MAP hose!
