Old 04-18-2012   #1
detch
detch's Avatar
Default Re: 95 lumbar pump not working
Took the motor apart anf found that is was seized up, so i lub the parts and also the rubber the holds it in the housing. Put it back together and it worked! Not as much pressure as a new one but does the job. i also looked into a 12V marine air pump and found one that might have worked for around $40 buckes. Did not buy it because I fixed the orginal. The other option I looked at was one from a different car which there were a few that looked to be about the same size but you would have to switch the connector or hard wire it in. Sorry no pictures, it took about an hr from start to finish. thanksMike
detch is offline   Reply With Quote
