Old 05-07-2012   #1
Default rock auto injectors
I was on rockauto.com today looking at some parts for my driver and decided to look up our injectors. they have several listings for the primary and secondaries, has anyone ever tried them? secondly has anyone used rockauto for parts
Old 05-07-2012   #2
VetteMed
Default Re: rock auto injectors
I use Rockauto all the time -- good prices, fast shipping. However, those injectors are all stock replacement style, as far as I know, and will likely not be ethanol tolerant, I suspect.
Old 05-07-2012   #3
John Boothby
John Boothby's Avatar
I have used Rockauto. Good service and they respond to questions!
Old 05-07-2012   #4
good to know. the honda needs pads/rotors and i need plugs for the zr-1
Old 05-07-2012   #5
Hoekie
Living in South Africa I have to rely on companies like Rockauto. I have used them often and must say their service is great.
I have only had a problem once and they went out of their way to rectify it.
Hoekie is offline   Reply With Quote
Old 05-08-2012   #6
fwiw, another positive vote for RockAuto! They even call me if they suspect that I ordered the wrong parts for my car while filling the order. Ya can't complain about that kind of customer service.
Old 05-08-2012   #7
I too have nothing but good to say about Rock Auto. However I suspect what Andrew said is prob correct. I dont think I would buy my injectors from them as they are prob a direct OEM replacement. Too much coin to risk vs replacing a blower module or a oil pressure switch. Its not worth the time or the battle or the downtime. Also it maybe a problm not immediately seen until the melting starts.
Old 05-08-2012   #8
VetteMed
I too have nothing good to say about Rock Auto. However I suspect what Andrew said is prob correct. I dont think I would buy my injectors from them as they are prob a direct OEM replacement. To much coin to risk vs replacing a blower module or a oil pressure switch. Its not worth the time or the battle or the downtime.
Hey Daryll, I think you mean you have nothing "bad" to say about RockAuto
Old 05-08-2012   #9
Yep too early in the morning for me lol. Fixed
