Old 05-19-2012   #1
Don in VT
Default Unusual fast idle condition
Hi All,
I have a somewhat unusual fast idle situation. When I start out cold, the idle is up around 1500 rpm. When I drive a few miles and come to a complete stop the idle comes to rest at 1200 rpm. I turn off the motor and restart and the idle, after a couple of seconds, settles down to 650 to 700 rpm. I have run this scenario a number of times and it is always the same. To the best of my knowledge I have no vacuum leaks.
Any ideas ?
Thanks,
Don
Don in VT is offline   Reply With Quote
Old 05-19-2012   #2
VetteMed
Default Re: Unusual fast idle condition
Don, the early cars' original PROM calibration was revised in later years to correct this very situation. You might want to consider talking to one of the chip burner guys out there to have the calibration updated if it hasn't already been.
I think Marc Haibeck's website may have some info about this condition.
Old 05-19-2012   #3
VetteMed
http://www.zr1specialist.com/HAT%20W...librations.pdf
Old 05-19-2012   #4
Don in VT
I goofed and didn't tell you that the ZR is a 90
I guess I didn't make myself too clear on my new problem which is just the reverse of the customary high idle problem I had for the last 2 years.
I now have high idle at hot shutdown but normal idle on hot restart. I can now shut the car off with a 1200 rpm idle and restart immediatly with a normal idle. I drive the car, bring it to a stop with a 1200 rpm idle, turn off the motor, restart the engine with a normal 650 to 700 rpm idle.
This condition just started yesterday.
Kinda makes ya wonder
This might take Mike H. to solve the problem.
Thanks
Don
Old 05-19-2012   #5
marks chip is so worth it
Old 05-20-2012   #6
scottfab
scottfab's Avatar
Since it sounds like you have normal idle at "open loop" time I'd start at the IAC. It's relatively easy to get of and clean.
Alternatively you could begin to isolate things at fast idle. (throttle plates sticking etc)
I take it blipping the throttle make no difference when it's at fast idle?
Scott
Old 05-20-2012   #7
Don in VT
Hi Scott,
I had to wait for my wife while she was at Zumba class and the same thought occurred to me. I will follow the FSM instructions on trouble shooting the IAC and go from there. The IAC that is in the car is OEM and therefore 23 years old
I suppose that is could also be a ECM issue but I doubt it. I will see if I can borrow a Tech1 from work and go with it as well.
Thanks for jogging my memory.
BTW, I was born and raised in Portland, OR. Worked and retired from Tektronix. Worked part time for Northwest Investment Cars in West Slope and the old Motorsports International (Used Porsche store) located also in West Slope. I am on my 27 Vette but included in all the Vette fun was owning a Pantera, a real Cobra 427 SC and many Porsche 928's
Have a great ZR1 summer.
Don
Old 05-20-2012   #8
I think Scottfab has a good suggestion. Sticking throttle. Once motor is shut off, throttle plate returns to stop because vacuum no longer applied to it keeping it slightly open. Check out the TB.
Old 05-20-2012   #9
Don in VT
Hi XfireZ51,
Thanks for the tip. I will do that tomorrow as well as checking and maybe cleaning the IAC valve.
Cheers,
Don
Old 05-20-2012   #10
gbmidyear66
I had the sticking throttle plate problem (secondary) and had Marc rebuild the TB for me (works great now). I notice he adds an extra return spring during his rebuild
