Old 06-25-2012   #11
Paul in VA
Default Re: 1992 ZR-1 VATS(?) problem
Hi:
I went through this same issue (intermittent starting). Drove me nuts for a while. Sometimes tilting/untilting the steering wheel would help. In my case, the car could be push started, just not key started.
I decided to bypass the VATS and found the problem. While removing the Key switch from the steering column, found the very thin wire leading from the key switch assembly (which had, over time) been crushed and the actual conductor exposed. After discovering this, I found this (broken/crushed wire) is a common problem with all VATS equiped cars.
Good Luck!
Paul in VA is offline   Reply With Quote
Tags
no-start, security, vats
