Old 07-05-2012   #1
Hammer
Hammer's Avatar
Talking Horns and Theft System
OK, guess it's not my week. My horns aren't working, so I got under the dash and pulled the fuse. Yep, it's blown. Replaced it, hit the horn, it blew once (and didn't sound right) and the fuse popped again. Tried once more and the same thing happened. Done for the night.
Anybody had this problem? What was the outcome.
Thanks
Old 07-06-2012   #2
rhipsher
rhipsher's Avatar
Default Re: Horns and Theft System
Damn John! Your car must be mad at or something.
Old 07-06-2012   #3
VetteMed
John, the internals of the horns can become partially seized due to corrosion. I'd suggest the following:
Unbolt the horns, spray a lot of PB blaster or equivalent penetrating oil down into the horn, let it sit. Tap on the center of the horn assembly with a hammer, after a few hours of soaking, to attempt to free up the mechanism. Might need to repeat a few times.
I suppose a faulty relay, or shorted wiring, could cause a problem too -- relay is under the RH side of the dash.
Old 07-06-2012   #4
Hammer
Hammer's Avatar
Talking Re: Horns and Theft System
That's what Im thinking.
When I was in Kennewick, parked at a hotel, the horns started going off. I was standing right there too. Noone around. I was thinking this happened when I wasn't around and maybe they just honked until the fuse blew.
Old 07-06-2012   #5
Hammer
Hammer's Avatar
I'll be looking at the horns and relay this morning. I wouldn't suspect faulty wiring until after those are ruled out.
AC is still blowing nice and cold Andrew. Thanks for your help on that again.
Old 07-06-2012   #6
VetteMed
This suggests that the signal wire is shorting to ground. The wire runs from the horn buttons, down the column, to the long connector for the turn signal switch, at the base of the steering column. The wire is black. From the connector it runs to the CCM, I think. When this black wire is grounded, the horn output from the CCM will latch the relay closed, to provide 12V to the horns.
Old 07-06-2012   #7
VetteMed
Agreed, re: wiring.
Glad to hear you're staying frosty
Old 07-06-2012   #8
Hammer
Hammer's Avatar
Checked horns with a Power Probe 3 this AM. The left one did not work and popped the breaker on the PP3. The right one worked fine. I pulled the left horn, replaced the fuse and the right horn worked fine, didn't pop the fuse after three times blowing the horn.
So, looks like I need a left side horn and this problem is fixed.
Old 07-06-2012   #9
VetteMed
Cool, glad to hear. You could still try soaking in PB Blaster to see if it frees up, before buying a new unit.
Old 07-06-2012   #10
scottfab
scottfab's Avatar
Sure glad these horns did not decide to do this crap in Kennewick. It's hard to have a nice BBQ with the noise
With such low mileage I'm surprised about this failure. Did it's earlier life happen to be in a state that uses salt one the road? Weird. Or did some under the hood spray maybe get in there? You know that stuff that shines up plastic.
Scott
