Old 07-10-2012   #601
Blue Flame Restorations
Default Re: LT5 Assembly Project
Lee, I have the same issue with my defective rear tires. After Pete's work, I just can't keep them from spinning every single time I drive it!!!!!!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 07-10-2012   #602
Brett,
It sounds like your really complaining about all that power. Pull a couple of
plug wires!
Old 07-10-2012   #603
Brett,
plug wires!
It's just aweful!!! Makes me want more cubes.....
Old 07-11-2012   #604
HAWAIIZR-1's Avatar
drove the car 320 miles the last 2 days, runs great....biggest issue is that these tires will never hook; gun it from a roll and the car kicks alittle sideways and burns them up....hope the dyno numbers match the seat of pants o meter.
BLMs at cruise are 116 and 128 at WOT
CONGRATS Lee! It sounds great and I know what you mean with new found power. I'm heading for Nitto NT05Rs to see how they hook up.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 07-11-2012   #605
Lee,
Sounds like we need to add fuel at idle and lean out cruise. BLMs will always show 128 at WOT because you are now in Open Loop. WB O2 is only way of telling what AFR is at that point.
Old 07-11-2012   #606
Isn't 116 a bit on the fat side for cruise?
I thought that you need to remove fuel to get to 128.. I always forget, since I have a program I created that does it automatically I never remember the actual formula without looking at my code... LOL
Old 07-11-2012   #607
HAWAIIZR-1's Avatar
Lee,
Dom,
What do you recommend for someone wanting to add WB O2 to their car and do you need to install dual bungs and have dual O2 sensors?
Thanks,
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 07-11-2012   #608
Dom,
Thanks,
for an accurate reading, before the Cats.. if you can I feel 2 are better then one..
Old 07-11-2012   #609
HAWAIIZR-1's Avatar
Thanks Jeff. I thought so and a friend said only 1 side really needed but it seemed you need two because even now with tuning it was found I have a problem on the right side with leak causing lean conditions. When I put my headers back in and install X pipe etc. I thought a good time to have the shop put bungs in even if I plug them for now, but could use when doing the dyno tune with WB O2s. I found one the Innovate system with dual O2s, but very pricey.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 07-11-2012   #610
out in the country/corn fields this morning on the way to work.....stopped revd it to 3K dropped the clutch and the car did a water box style burnout without using the brake, just sat and smoke the tires....lovin the car...
Every Z needs porting and cams...
