Old 08-12-2012   #1
SAM/CH ZR-1
Default WTB: 63mm Trottle body
If not available I also take a stock TB. Futher look for a plenum and air horn as well.
Shipping would go to South Georgia.
Only realistic prices please.
Sam
SAM/CH ZR-1 is offline   Reply With Quote
Old 08-12-2012   #2
Default Re: WTB: 63mm Trottle body
PM me Sam with an offer for a TB , plenum and air horn shipped to SGC.
Old 08-15-2012   #3
Paul in VA
Hi Frank:
Not trying to intrude... just learn...
What would a larger Throttle body do for an almost stock (headers, chip, exhaust) car?
Paul in VA is offline   Reply With Quote
Old 08-15-2012   #4
Originally Posted by Paul in VA View Post
Hi Frank:
No intrusion at all Paul. A 63mm would do very little if anything to even a lightly modded car. I'd spend that money on a set of Pete's CNC'ed plenum and injector housing set-up. Now that's bang for the buck you'll enjoy. I'm pretty sure that Pete has a set already done so the mod is done fast and easy with no waiting. If by chance you need a loaner setup , I may have a loaner's you could use.
Old 08-15-2012   #5
Paul in VA
Hi Frank:
That is very thoughtful! Thank You.
I just now, two days ago, got my almost stock ZR-1 through VA emissions inspection (took me six times through the e-inspection process to finally pass; if you are interested, PM me with your email address and I'll send you more than you ever wanted to know about this grueling process and my changes/results) and I have one more emissions inspection to look forward to before my car exceeds the 25 year old mark, when I no longer need to go through emissions inspection, just mechanical inspection. I am very hesitant to change anything engine wise that could impact passing the emissions inspection, for a couple of years.
Old 08-15-2012   #6
Hi Frank:
Emissions inspections: Reason #73 I moved from VA
Old 09-05-2012   #7
SAM/CH ZR-1
I am still searching a TB, Plenum and air horn
Sam
Old 09-05-2012   #8
cvette98pacecar
Sam
Dont know if it is still available, you should contact the seller.
http://www.zr1.net/forum/showthread.php?t=17776
