Old 10-27-2012   #1
vilant
Default Spark plug gap
I was told from the auto parts store clerk that NGK recommends .05" gap. But in Solutions it says .043" on a 91'. I have a '90. My question is: What gap size is correct .05" or .043"? TIA
Old 10-27-2012   #2
efnfast
Default Re: Spark plug gap
This was the answer I got from Mr. Haibeck
Hi Steve,
For high load operation I recommend a spark plug that is one AC heat range cooler than the OE plug. The best spark plug is the NGK TR7IX. Part number 3690.
It has a tapered seat. All LT5's are machined for both tapered and flat seat plugs. Carefully open the gap to .050"
Best of luck.
Marc
Old 10-27-2012   #3
vilant
Thank you very much.
Old 10-27-2012   #4
efnfast
Piece a cake. That's what I did, with no regrets.
Old 10-27-2012   #5
vilant
He wasn't kidding about being careful. How're you suppose to bend the ground without breaking that tiny tip? I'll try needle nose.
Old 10-27-2012   #6
efnfast
Don't break 'em, they're expensive. My gaping tool had an end to open the gap, but yes, be careful.
Old 10-27-2012   #7
efnfast
I also read somewhere that not all the heads were tapped for both. The plan was to over torque by 25 pounds to kinda make a tappered seat.
Marc has seen plenty of heads and I would ASSUME he's right. I think I over torqued some, maybe not 25 pounds, backed them out and retorqued.
Old 10-27-2012   #8
scottfab
scottfab's Avatar
As with many issues this has been covered as far back as 98 on the mail list. (and maybe earlier) Unfortunately the archives on the Club pages only go back to 2000.
This is the earliest found there:
http://maillist.corvettemuseum.com/c...R1NET&P=R21105
Scott
Old 10-27-2012   #9
vilant
Thanks, fellas. The new plugs had the same end as the old ones. I torqued them to 22 ft/lbs, per the FSM.
Old 10-28-2012   #10
scottfab
scottfab's Avatar
At least you don't have to worry about the gap effecting the dwell or timing.
Ah the 60s ... =D>70s.
Some things really have improved.
Scott
