Old 04-06-2011   #11
limey
Default Re: Little White hose Clip thingy
Put me down for 10.
limey is offline   Reply With Quote
Old 04-06-2011   #12
mike100
91's have that...mine's broke too. If you make 50 pcs, that probably wouldn't be enough.
Old 04-06-2011   #13
Emilee
I'll take a couple
Emilee is offline   Reply With Quote
Old 04-06-2011   #14
VetteVet
VetteVet's Avatar
I'll take two, Lee.
Thanks,
Jep
VetteVet is offline   Reply With Quote
Old 04-10-2011   #15
Well I have been working on a mold for this clip....then today I am out in the garage and my neightbor asks me to help him with an issue he is having with his Acura. We finish up, and as I close the hood, I go to put the prop back, and there is a nearly identifical clip. Thats why the white clip does not seem to match the LT-5 Engine compartment...its judt a hood clip
So I just need to find the correct hood prop clip....
http://www.thefastenerconnection.com...pRodClips.html
This one looks close
PN#: 14345
Colour: Nylon (white)
Holds Rod Dia: 10mm
Fits Hole Dia: 8mm
Hood Prop Rod Clip
OEM#: 24220-89986
Old 11-22-2012   #16
Lee been a while did this ever happen I need a few of these. GC
Old 11-22-2012   #17
I am pretty sure its just a hood prop clip sourced from another car....did not find it....
Old 11-22-2012   #18
Close....not sure on size...
http://www.ebay.com/itm/Mazda-Ford-N...-/230653464611
This one looks close too
http://www.ebay.com/itm/Toyota-Picku...48bac4&vxp=mtr
Old 11-22-2012   #19
WVZR-1
What is the diameter of the tube and also the hole where the clip is fastened? If your vernier does metric it's generally easier to work with metrics these days.
Hood prop rods are generally larger than I believe required. I'm quite sure I did a GM number for these once but they've been NLA for a while.
Old 11-22-2012   #20
Does anybody have a close up pic of this actual part. I want to look at Ace and a few help sections.
