Old 01-01-2013   #11
WVZR-1
Default Re: Non-stock wheels/brakes? What about spare tire?
Brett,
Maybe you could measure the barrel diameter on that spare and I can compare to the Z06 wheel.
I've read I'm quite sure that the only "direct-fit" compact spare is the '08+ CTS which is like the GTO but with a larger barrel and an appropriate offset. The compact is like the older CTS - it's an add on option that most don't have or even ship with. A salvage yard buy would be probably not possible. I believe they might even be used as "skinnies" like the C5 guys do with the GTO.
The package part # is 19179359 and it's an 18 X 4 complete with tire, compressor and accessories.
Old 01-01-2013   #12
tf95ZR1
tf95ZR1's Avatar
So any new recommendations on what to use as a spare
over C6 Z06 calipers other than Fix-A-Flat?
Old 01-01-2013   #13
Robert wheel poll got me to thinking. So now that I have upgraded to Z06 wheels and front brake calipers, what to do for potential flat? Staggered wheel sizes complicates things a bit more. Right now I've got a can of flat fix and compressor.
Anybody else w suggestions?
Well I know your not running wheel sensors DOM but Fix a Flat will hose those up for sure if you were.
All things considered a Triple AAA tow or I have towing via my insurance CO to the nearest facility. Or leave it there if you can pull the wheel etc.
Old 01-01-2013   #14
Mystic ZR-1
Mystic ZR-1's Avatar
tire plug kit
wire cutters (for pulling out nail)
12v compressor (plug into cigarette lighter)
fix a flat, just a squirt (may help plug seal)
of course if you ripped a big hole in the tire you're screwed...
AAA card, "don't leave home without it" (especially in a 20 year old car)
Old 01-01-2013   #15
mike100
Maybe the elusive CTS 18" spare might fit...almost certainly it could with a spacer. I thought about picking one up for my C6, but i have not been looking lately.
I'm running the 17" GTO spare with my C5 caliper conversion on my 91 though. Been there-done that on the whole not having a spare when you need one thing.
Old 01-01-2013   #16
mike100
Old 01-01-2013   #17
WVZR-1
The 18" CTSV should wholesale for maybe $360 or so and most/some Cadillac dealers stock them. If you've got a "relationship" with one you could maybe arrange a "trial fit". I supplied the correct part number I'm quite sure. Need to remember the bolt circle for the GTO and the CTS-V is 120mm not 120.7 or the implied 4.75". It's not considered an issue!
I believe I've come across a "stumbling block" the CTS-V is only a 66.9mm center-bore so the wheel center would need opened up to the 70.3mm dimension. There would be no sure "trial fit" but I would think it would slip over far enough to confirm that it would be a "go"!
Actually a GTO should require a minor trim for fit also for those interested. It's 69.5mm I believe.
"Mike100" should be able to confirm the "minor" modification required. It might "force fit" being less than 1mm difference.
Old 01-01-2013   #18
Blue Flame Restorations
Yep, I had to trim the hub hole on my GTO spare.
I do have AAA Road Insurance though.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 01-01-2013   #19
WVZR-1
From CF -
The CTS spares require a 1/2 spacer/adapter.......the GTO spares require a 3 1/2 adapter. This to clear C6 - Z06 brakes. I lost the link and was going to post a couple snapshots. I thought I had read 3 1/4 previously for the GTO spare but couldn't find it the 2nd time. The spacer/adapter price would kill that idea!
Old 01-01-2013   #20
mike100
Originally Posted by WVZR-1 View Post
From CF -
I saw the post with the 3.25" adapters- that was ridiculous, but for a functional spare (and not a drag skinny), A 1/2" adapter on a CTS wheel would be ok considering it is your only option- you'de just have to have the extras tool and hardware on hand to bolt it up if you needed the use of the donut.
Tags
emergency, flat, spare tire
