I cannot program the settings in any way (Setup Wizard, for default settings, Advanced Options, etc.).
If you're at all familiar with this controller, please have a look at this post in TCI Product Support Forum http://www.cpgnation.com/forum/contr...10-a-8065.html I haven't traced the controller module wiring yet. If out-linking is verboten, sorry - wipe it, if out of order. Thanks here... |
![]() Join Date: Jun 2012
What is the controller actually supposed to do?
Changes TC lock up RPM, shift points low (and high) by TPS, shift engagement firmness, etc...
Setup Wizard bases operation on tire size, rear end gearing, does a TPS calibration for range, etc. I had a vid of live data read, but the handheld screen doesn't show... Last edited by Schrade; 01-19-2013 at 08:40 PM. |
I see, well I've never had any experience w/ it, sorry. Hasn't "support" for the product gotten back to you.
#5 | |
![]() Join Date: Oct 2004
I've sent you a link for the install and documentation! |
![]() Join Date: Dec 2003
If your getting comm error,i have found the 3 wires at the controller plug are crossed.i can't remember which one is wrong,i will have to look at the local auto Z's plug.
I will have to get back to you with this info. Pete
Got the link (and saved) Dave; that's my control module -
Pete - I have begun the wiring trace, and found some crappy connections at a newly found device 'Dakota Digital SGI-5 C'. ![]() ![]() Anyway, this is what I found... I'm hoping this is the source of the Comm Error, but I know that I HAVE TO trace all lines... ![]() AND THANKS FOR THE FLEXPLATE TOO THERE, PETE!!! ![]() |
Schrade,
Looks like real quality work. NOT! Is that supposed to provide a VSS signal? |
I would have thought the Dakota Digital could have been avoided. Those devices can raise hell with most of the things that are troubling you. I believe the cruise is difficult to accomplish and who knows whatever else.
I guess it's sort one device at a time! When I looked at the transmission controller it seemed pretty straight forward and I believe I understood it, I understand what it would have taken for the VSS to function as intentioned also. Last edited by WVZR-1; 01-20-2013 at 09:58 AM. |
#10 |
Yep. That's what it is.
http://www.dakotadigital.com/pdf/sgi-5c.pdf Can't tell by pic but it looks like there's no sensor ground. |
