Old 05-23-2013   #11
Default Re: Tony D's Project corner (Oil catch cans) Part 2
Thanks for the info Tony..
I have one catch can.. top is intake vaccuum, bottom goes to the PCV valves which come from the IH so mine is similar but our PCV are in different locations in the path.. not sure it will make a big difference where those are though
Old 05-23-2013   #12
Schrade
So you HAVE integrated the catch cans in vacuum 'series' with the PCV?
Old 05-23-2013   #13
Mine are:
Intake Vacuum -- Top of Can -- Bottom of Can -- Top of PCV -- Bottom of PCV -- IH
Old 05-23-2013   #14
Schrade
Mine are:
So that should be the best way - right? Gets the oil out of the line ASAP???
Old 05-23-2013   #15
Tony Davila
Tony Davila's Avatar
No difference before or after as long as it is in the path.
Tony Davila is offline   Reply With Quote
Old 05-23-2013   #16
SO now.. any more pics of the mods on your car?
details on that hood?
Old 05-23-2013   #17
Tony Davila
The purpose of the PVC is so that when you are WOT the PVC stops or minimizes the oil from being pushed in by the pressure created by the crankcase.
We all know it doesn't work to well. At WOT there is no vacuum present on the crankcase, the pressure then builds and oily mist start leaving the IH. Having a oil catch cans helps in capturing this oily mist and prevents it from being ingested into the intake.
Old 05-23-2013   #18
Tony Davila
Originally Posted by tf95ZR1 View Post
Tony:
Very cool custom car!
How did you secure the ends of the header
heat wrap?
Next: a write up about your meth system.
I used stainless mig wire and header bands to secure the wrap.
I already did a write up on my water/meth injection.
