Old 05-26-2013   #101
PhillipsLT5
PhillipsLT5's Avatar
Default Re: Group buy on anti-hood prop failure piece
Worked for me with this
http://www.ecklerscorvette.com/corve...1986-1996.html
1991ZR1, try removing the orange plastic piece
Old 05-26-2013   #102
tf95ZR1
tf95ZR1's Avatar
Copy
Old 05-26-2013   #103
tf95ZR1
tf95ZR1's Avatar
Damn, Phillip! $230 for a chrome hood strut!
On Sale!
That's quite a few gallons of 103 octane racing fuel
Old 05-26-2013   #104
Blue Flame Restorations
Mine works fine on my 91 with the orange piece on the hood support
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 05-27-2013   #105
1991ZR1
I tried it again and it won't fit. It can be forced in, but it bends the plastic piece. I think I can make it fit by making a groove or channel in the flat surface of the device. I would guess that I need to remove about 3/32" of material.
I think the plastic piece is there to make it easier to center the strut into the tube when closing the hood so I wouldn't want to remove it.
1991ZR1 is offline   Reply With Quote
Old 05-27-2013   #106
carter200
carter200's Avatar
You have a choice. Keep your orange tab (first one I've ever seen) and have a hood that can/will fall at anytime on you or others or remove the orange piece and have a safe to work around hood.
My previous post about returning the anti-fall hood prop key still stands. Remember that the intent of this key is as a safety device.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 05-27-2013   #107
I have a 91 with the orange plastic piece. Mine fits fine BUT I have to raise the hood just beyond the stopping/resting point before it will slide into place. No problem. Just raise the hood about 1/4" more and slide it into place before you lower the hood back to the final stopping/resting point..
Old 05-27-2013   #108
1991ZR1
[QUOTE=Blue Flame Restorations;174231]I have a 91 with the orange plastic piece. Mine fits fine BUT I have to raise the hood just beyond the stopping/resting point before it will slide into place. No problem. Just raise the hood about 1/4" more and slide it into place before you lower the hood back to the final stopping/resting point.
Thanks for the tip. It does work and fits snuggly. Will definitely not fall out.
Old 05-27-2013   #109
[QUOTE=1991ZR1;174234]
Glad it worked out for you.
Old 05-27-2013   #110
carter200
carter200's Avatar
[QUOTE=Blue Flame Restorations;174237]
Glad it worked out for you, too
When you are ready for some billet goodies give me a holler
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
