Old 03-25-2007   #1
zr-1assassin
zr-1assassin's Avatar
Default LOW-TIRE-SENSORS if i remove them???
hi all, im putting on new wheels and want to know what it will do if i dont put the tire wheel sensors back on? will i get an idiot light or can i turn the light off? whats the deal with these? any info is helpfull......thanks
zr-1assassin is offline   Reply With Quote
Old 03-25-2007   #2
RICHARD TILL
Default Re: LOW-TIRE-SENSORS if i remove them???
i removed the sensors and bulb on my 90Z about a year ago and have`nt had a problem.
Old 03-26-2007   #3
zr-1assassin
so the light will come on if i dont put them on the new wheels? how much of a pain is it to remove the bulb? it wont mess with anything else will it? thanks for the reply!
Old 03-26-2007   #4
RICHARD TILL
i do`nt know if the light will come on without the sensors. my ltpws light came on all the time with all the sensors on and tire pressure was good. i removed them two at a time when i replaced rear then front tires. i got tired of having to put a piece of paper in front of the lights so i removed two bulbs, the service LTPWS and the low tire pressure light. they are 194 bulbs. you`d have to first remove the plastic piece around the shifter including the ashtray, then the bezel covering the radio. then four screws to take the cover off the warning lights. its not that big of a job. i think whatever that system initally cost was a waste of money. good luck and i wish i could be more help. i just know that you`ll have no problem because of the bulb removal.
Old 03-26-2007   #5
zr-1assassin
thanks, i think i'll just give it a try and remove the light bulb if needed. just wanted to make sure i wasn't going to screw anything up. these cars have been known to be like no other!
Old 03-26-2007   #6
Hammer
Hammer's Avatar
Talking Re: LOW-TIRE-SENSORS if i remove them???
I removed the sensors when I put new wheels on and have not had any problem with lights coming on.
Old 03-26-2007   #7
Aurora40
Aurora40's Avatar
90's won't have the light if all the sensors are removed. Mine are in the basement.
Old 04-04-2007   #8
ffvetteman
I agree. I changed rims and tires on my 92 and did not put the sensors on the new wheels. After about 150-200 miles the service LTPWS light came on. I did the same and pulled the bulb, no problems .
ffvetteman is offline   Reply With Quote
Old 04-04-2007   #9
tf95ZR1
tf95ZR1's Avatar
Is it a big deal to pull the bulb?
An explanation: Ideally, I'm not against these LTPWSs. The light has only turned on when a tire was low. They work. I also have not had one fly off (yet) even up to 152 mph (thanks Dwight!). My complaint is that 75% of the time whenever I have some BOZO change my tires, they break the sensor. I warn them, tell them they are mounted opposite the valve stem, they are expensive to replace and they WILL pay for new ones, and they still break them. I then have to wait until the new ones arrive and again remount the tires.
IMHO, not the swiftest engineering by the general. OK, I'm done ranting....
Old 04-04-2007   #10
Peaven
Peaven's Avatar
Pulling the bulbs is not a tough ordeal...if you want, I can send you a short writeup on how I did mine when I changed out the head unit..
I'm definately pulling my sensors off before BG.
Peaven is offline   Reply With Quote
