Old 08-03-2013   #1
Schrade
Default Driver for datalog hardware...
edit: It's now a different problem:
It's now a 'Hardware Not Found' issue (for TunerPro 5.0).
DataMaster - Z1 says, "ALDL is working, but no PCM detected."
I did download the '90, '91 LT5 version from DataMaster website.
Help?
Old 08-03-2013   #2
Franke
Default Re: Driver for datalog hardware...
Shrade,
I had to download a similar uart driver for my laptop as it didn't have a usb driver for my TTS datamaster as well. Go on the web and type in the search box ft232 uart usb driver. I beieve you will find one you can use.
Old 08-03-2013   #3
Schrade
Originally Posted by Franke View Post
Shrade,
Thanks there Franke...
Help?
Old 08-03-2013   #4
Tyler Townsley
Are you using a serial to usb converter? I had to use the software that came with the converter to get my FJO dual wideband setup to work. I am going to try Tunerpro tomorrow, will let you know.
Tyler
Old 08-03-2013   #5
Schrade
Tyler
Thanks Tyler - yes, using a serial to USB connector. Seems to be a common problem, psoted about in 2003. Still not fixed by programmers...
"Disable CCM Handshake" ( a recognition problem ), did not fix the problem.
They have to do better than this...............
Old 08-03-2013   #6
Schrade
Changed COM port to port 4; CCM detected.
Still no readings displayed...
Old 08-03-2013   #7
Schrade
Got a connection with monitoring.
Looks like some problems somewhere here (will Copy / Paste readings shortly for feedback from TUNERS!!!).
edit:
DataMaster didn't record a DIACOM file to play back.
WTH???
Old 08-03-2013   #8
Franke
Schrade,
What version of datamaster are you using and what year is your car?
Old 08-03-2013   #9
Schrade
Schrade,
90-92 Y-Body 5.7L (ZR1) DM35xZ1 - Complete Installation
Little bit of progress beyond original problem here, Franke...
Old 08-03-2013   #10
Franke
Try recording a datamaster file and playback of the datamaster file instead of diacom
