Old 04-03-2013   #11
Daniel_Mc
Daniel_Mc's Avatar
Default Re: Does the ZR-1 Require a special tow hook or other towing requirements? ---
Front Tow hook:
One thing to mention the front bracing on this Z is all welded not bolted like a stock car FWIW.
-Daniel
Old 04-03-2013   #12
Daniel_Mc
Daniel_Mc's Avatar
Rear:
-Daniel
Old 04-03-2013   #13
Daniel_Mc
Daniel_Mc's Avatar
Do you have dimensions of this adapter?
I assume you made this adapter yourself?
Did you make any extra in that color
Thanks,
Cliff
Cliff,
No this was someone that I was racing with at the time. He made this for his car and I have just saved the pictures. I'm sure I could mock something up for the dimensions.
Daniel
Old 04-03-2013   #14
Daniel_Mc
Daniel_Mc's Avatar
Cliff,
Thanks but I cannot take any credit on the tow hook. The hooks are original equipment on this ZR-1. The rear tow had been removed at some point in the cars life. However the mounting hardware was still attached. I used a leaf spring U to make the new one and it worked like a champ. The original builder of the Z trucked it around on a semi with the race cars and pulled it in and out of the trailer with the hooks. At one point one of the cars failed and they were using the Z to tow it off the track and back to the pits. The hooks seem to have held up good over the years I see no fatigue or distortions to any part of the hook/frame/or body.
The rear you could make for less than 10 and the front probably the same if you have the tools to weld it yourself. The front just need to be placed in a break to get the angle. I have been meaning to make a few sets but work and life have me slammed at the moment.
Daniel
Old 04-03-2013   #15
HAWAIIZR-1's Avatar
Originally Posted by Daniel_Mc View Post
Cliff,
Daniel
Daniel,
Great stuff and I don't mind being on your waiting list when you have time to make a few sets. Thanks for sharing!!!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 08-14-2013   #16
Absolutely love the tow adapter
Makes loading the car in the trailer soooo easy!!!!
Thanks cliff!!!!
Old 08-14-2013   #17
scottfab
scottfab's Avatar
Here ya go
Scott
Old 04-27-2014   #18
emmvette
emmvette's Avatar
Default Re: Emergency Kit
Emergency Kit.....15 ft tow rope (5,000 lb vehicle rating), Jumper Cables, Tow Adapter, Lug Wrench
Daniel_Mc provided a concept/photo of a Tow Adapter for a ZR-1 that in its simplicity I just could not pass up
So......I designed one after the photo provided by Daniel_Mc and had a local steel shop fabricate the Tow Adapter.
I did some towing tests to see if there are any issues or limitations. One limitation will be towing at an angle in a turn which this adapter without being bolted on the back side of the cross member will not function (that did not seem to be an issue during the tow tests). The Tow Adapter is made from 1/8 inch steel plate which is substantial and flexible enough to tow the ZR-1 with Nylon Tow Ropes having a steel hook on one end.
The Tow Adapter is made to engage the 1-1/4 inch square tubing of the frame support under the front of the ZR-1.
Post 16 - Lifting and Towing the ZR-1
Dynomite: Did you make extras? I am interested in buying a tow hook to install on my car for winching it up into a trailer.
If these are available, please let me know. If somebody has other suggestions, please share.
Thanks
emmvette is offline   Reply With Quote
Old 04-27-2014   #19
edram454
edram454's Avatar
I like the look of this and it is a good idea. How long does it stick out?? I have seen many c5 corvette with tow hooks installed running around all the time. Is this installed with bolts or just to place on metal bar and pull? I am interested in one of these. You never know..... Do you make them?? Price?
ed ramos #3028
Old 04-28-2014   #20
Originally Posted by alwayscode390 View Post
I hope to never need a tow with the ZR-1 , but as we all know ... our cars are getting relatively old now.
I know the Viper guys keep a set of spare "r-hooks" in their car. Supposedly they fit in the frame correctly and most tow trucks don't carry their own set ... or enough of them.
Is there any towing requirements for these vehicles? Should I invest in anything to keep in the car "just in case"?
Thanks ---
Here you go
http://www.zr1.net/forum/showthread....ghlight=towing
