#11 |
![]() Join Date: May 2013
one more pic. IMG_0006.jpg.
#12 | ||
You are DA MAN Franke...Franke "took apart" an FX-3 Actuator for us....
1. Photos of FX-3 Bilstein Actuator taken apart. Franke......those are great photos....appreciate it. Quote:
![]() ![]() ![]() ![]() 2. Actuator Rotating Mechanism (How the Actuator Rotates the shock gear shaft which in turn aligns various ports within the shock). Quote:
![]() ![]() 3. Actuator Operation and Initial Installation of Actuator on FX-3. When you turn the key to "Run", the actuator goes CCW and then back CW or CW and then CCW.....but both directions like it is searching for end points. Apparently when you install the actuator on top of shock you do not have to align the gear on top of shock.........But I did I centered the gear as it rotates I think 160 deg total and I centered at 80 deg from one stop....but I think that was not necessary. The Actuator gear teeth (you can see the gear looking in the open end of the Actuator) which are plastic get broken. I had a front Actuator just dead in the water recently (electrical issue). 4. Used Actuator Source. Corvettenutz has used Actuators in stock. Ebay ZR-1 FX-3 Bilstein Shock Actuators 5. Actuator Part Numbers. 92-95 front Actuator part # is 22114407 (rear is part # 22114337). I actually had an extra Actuator #22114407 (92-95) which worked fine on my 91'. The 89-91 front Actuator part # is 22075651 (rear is part # 22075652). The 89-91 Actuators and 92-95 Actuators are interchangeable as far as I know (the difference between Rear and Front Actuators is the length of the attached electrical cable). 6. Actuators Can Be Repaired. FX3 Actuator Rebuild TIPS
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-29-2013 at 08:26 PM. |
#13 |
No worries. It was a dead actuator. Motor was frozen but the plastic gear was in good condition. Can ya believe it.
#14 | |
The other was the '90 Z headlight motor nylon gear, rotated after dis-assembly, and finding it cracked, while waiting for the new nylon gear in the mail. The new gear is on the shelf, while the rotated cracked gear is still working for 5 months now. The GMC CC module is still on with the cracked gear, for 3 years. Last edited by Schrade; 08-31-2013 at 02:57 AM. |
#15 | |
#16 |
Yep - it doesn't appear 'serviceable', in like manner.
I can delete my post if you think I should........ |
