Old 10-11-2013   #11
Default Re: Removing steering wheel for aftermarket .. Questions ..
Not sure about a 94 but I pulled the AIRBAG fuse on my 91 and the car wouldn't start.
Old 10-12-2013   #12
Locobob
Well that is interesting... I guess you just pull the fuse to work on/remove the airbag as a safety precaution then replace it when you are done. Sounds like there are two ways to defeat the airbag trouble light - either install a resister and prevent the trouble light from coming on or remove the bulb so you cant see it.
Robert
Old 10-12-2013   #13
Locobob
Originally Posted by WVZR-1 View Post
Robert - there are hubs of various heights to place the wheel where you might like it. Very easy to determine the height required.
I think I'm going to do the NRG quick release, guess I'm going to have to call them to see which hub is gonna work. I wouldn't mind moving the steering wheel just slightly closer to me for driving comfort, maybe an inch or so.... I have long legs so I drive with the seat nearly all the way rearward.
Robert
Old 10-12-2013   #14
Or bag fuse also powers the ecm, you can remove the DERM and jumper a wire and the car will start. I learned that stuffing a 91 dash in my 89
Old 10-12-2013   #15
WVZR-1
The height of an early '90 - '93 steering wheel is 6" and I believe the '94+ should be similar and I believe most of the after-market are considered 0 unless advertised as deep-dish and then they mention the depth of the dish. The 6" is measured to the furthest surface of the steering wheel not the center of the diameter of the steering ring. The after-market I believe I've seen advertised both to center and to the furthest surface. Subtract maybe 5/8" to center height of steering ring for the OE/GM.
Old 10-24-2013   #16
5ABI VT
Here's a few photos I dug up.
Forgive the aluminum stick on trim.. I laid it in place to see what it would look like.. safe to say it was an easy decision to toss it in the trash. Had the wheel on here, cant recall if the nrg hub was on in the pic
Here's a side by side of the momo and hub beside an oem 93 wheel.
If I remember right there are 2 hubs that will work and one is taller so there are options on where you want the wheel. I chose the shorter hub and nrg hub to get it where I wanted. I also shimmed the column
Old 10-24-2013   #17
What model wheel is it..hard to see in the pictures
Old 10-24-2013   #18
5ABI VT
Cant give away all my secrets j/k Ill dig up the model name I cant remember as ive had it for over 8-9 years or longer.
