#131 |
Vid uploaded on alternator housing paint - I'd gotten a couple of PM's about laying colors on the plenum, and TB extension paint / decals. Not too much difference here, except for Aluminum paint...
It does NOT have polyglass + MEK hardener mixed into the paint - I haven't checked on miscibility in Aluminum paint. Anybody know already??? Lenny DaVinci I ain't; maybe I oughtta' check into Holiday Inn Express for a night or 2 here... vid |
#132 | |
Anyway here, how did you know it's a 'thing'??? Kinda' flattered actually ![]() No - haven't got it re-assembled [again] yet. And still thanks for the TB butterfly screws too! ![]() The paint on the alternator fan WAS not right. Like PW said, balance IS a consideration, and I'd thought of balance as I hadn't thinned it, or mixed poly/MEK in it. It definitely would have made for a balance issue, with some sags on one side. And stripping the paint off the fan was a PAIN. Doesn't matter - not enough Global Warming to work outside right now anyway. My 'garage' is the perfect compliment to Lincoln's birthhome - ONE wall. And I ain't no popsicle. Plus the missing bolt is still in the same place where I found it with the spycam - and I don't have a clue where it actually is. Gotta' replace one of the coolant manifold elbows too. Curious about Samco stuff - anyone ever heard anything about Samco stuff? Cliff by chance maybe? Last edited by Schrade; 01-05-2014 at 02:05 PM. |
#133 |
![]() Join Date: Dec 2003
"Samco" is a company that makes silicone hose products.
We now have un-branded reinforced silicone coolant hose sets and high quality SS clamps. http://www.zr1.net/forum/showthread.php?t=21668
#134 | |
I have a set of Red Samcos on a 91' and a set of hoses from Marc Haibeck (non silicon but perfect fit) on a 90'. They are installed ![]() Engine Coolant Hoses
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-05-2014 at 05:23 PM. |
#135 | |
![]() Join Date: Jan 2009
Your vid motivates me to do so even more ! Thanks
Scott ![]() Vett owner since 1979._It's about the car and the people Last edited by scottfab; 01-07-2014 at 11:39 AM. |
#136 | |
I'm just trying to avoid the hesitation issue - hoping that the Z-Gods will make it will go away ![]() |
#137 |
![]() Join Date: Dec 2013
Just a thought but if you are concerned with the heavy amount of paint on the brush, you might want to dab it into a paper towel to remove excess and then keep going back to your original amount laid on the part to thin it out. That is what my daughter (the painter) does with her work so that it's not to heavily applied. (Just in case you are planning on painting more parts but NICE JOB).
#138 |
Are you saying you had a vacuum leak at the PCV tube? BTW, I have an extra of those.
#139 |
![]() Join Date: May 2013
Chuck, if you didn't have bad luck then you wouldn't have any luck at all.
#140 | |
fit down the spark plug hole? Mine wont' quite fit.
