#11 | |
![]() Join Date: Oct 2004
Plews/Edelmann and Omega also show interchanges as well as NAPA, I would have thought most of the calls you made yesterday could have offered "next day" service but of course it would have depended on "time of day" likely. Curious - where did you source your steering rack? |
#12 | |
#13 | |
o Rebuildable / re-usable genuine Aeroquip hose ends (no crimping required) o For use with '80 and newer 18mm / 16mm O-ring style brake assist units o For use with O-ring and / or flare style Saginaw full size or mini PS pumps Power Steering Adapters Hosewarehouse Racing Hose Fittings And my favorite for SS Braided Hose and Aeroquip Fittings....... Summit Racing
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-16-2014 at 11:46 AM. |
#14 | |
Now could you salvage the tubing, use hose and crimps to replace just the hose - that could be very "doable" and I've done that to replace obsolete AC fittings - the PS system at probably 850 - 1000 PSI or so and nearly 3 GPH I don't know that I'd want to attempt that. |
#15 | |
"concoction" "quick reach" and "try again" ![]() You remind me of someone else and the words he uses all the time "kludge" "ripping" .............. ![]() All those terms seem negative to me... My Guru (an absolute ZR-1 expert and Daryll knows him also as the guy who got me started in this Hobby)......just sent me this bit of information.............I am still going to experiment..... ![]() I was focused on what I could see above the Steering Rack......and NOT the pump connections. There is a specific kink in the pressure hose to allow it to fit behind the pump. Most places that build hoses can not replicate it due to where it is. And there is no fitting a aeroquip line due to the space constraints because you would have to use an adapter. Autozone sells and will deliver a hose. Part number 71778 Power Steering Pressure Line Hose
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-17-2014 at 10:42 AM. |
#16 |
Thanks for all the info,got one from auto zone had to order it will be here Friday .rack & pinion got from vette products here in lake Orion Michigan,thanks again guys
#17 | |
The A-zone replacement hose is pretty inexpensive - almost scary "cheap". It might be interesting to see whose packaging it arrives in. The part number indicates it's likely Plews/Edelmann but I see that maybe Plews has purchased Omega which would have been a different part number. Last edited by WVZR-1; 01-17-2014 at 09:34 AM. |
#18 |
it was leaking in the middle almost looks like a big rivot or stamp towards bottom guy says cant fix it need new one.
#19 | ||
TomZR1 - you're not making much sense here. How did the R&P install go yesterday? |
#20 |
Rack and pinion install went real good the reason why replace the power steering lines is because they said it was sweating whatever that means, and found the line at AutoZone got it the next day
