#21 | |
![]() Join Date: Nov 2013
did you see that map! I live in the (69) degree area. It's balmy all year around and eggs hatch all year and battery tenders work all year long too. Love those things. I have a cigarette lighter adapter... so easy to install and works like a charm. They will go bad over time since I recently replaced a tender that had been working solid for 3 years. I bought two more.. they are inexpensive at 34.00 each. Highly recommend. ![]() ed ramos #3028 |
#22 | |
![]() I have to admit.....Several times I left the ignition switch on (counterclockwise) for the radio just to listen to the CD while working on the LT5 ![]() And a couple times had to put a charger back on to start it ![]() Doc Dons will fix your right up ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-21-2014 at 10:51 AM. |
#23 |
#24 |
Ca and it is close to 70 deg here all this week
![]() And to keep on topic....I do NOT use Battery Tenders here in CA either ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-21-2014 at 11:09 AM. |
#25 | |
![]() Join Date: Nov 2007
#26 |
Just my two cents, I saw this thread and like to add that my experience with the "battery tender " has been excellent. I used them on my race car when not in use, my 05 CTS-V which is not driven much at all, My ZR-1 that gets about 1000 miles per year , even my zero turn mower. I absolutely love the product and the quality is first rate. Pryor to purchasing these battery tender jr.'s I was experiencing battery issues on every vehicle mentioned as well as my mower. I love them and have had absolutely no issues. I have been using them now for about three years.
#27 |
![]() ![]() Join Date: Aug 2005
Hey Dyno, where are you in CA?
If close, maybe we can GTG ![]() |
#28 |
I am up in Central Valley ......sometimes
![]() We do have several ZR-1 Owners in CA but trouble with CA is driving distances North to South is 800 miles ![]() Just so I do not sound too negative.....I DO LIKE CHICKEN TENDERS at Applebees ![]() Now for you Battery Tender guys like Daryll and Paul (we know what kind of music they listen too) and everyone else in this thread ![]() You DO NEED a Battery Tender if you do NOT Disconnect your batteries..........DO EXPECT hard or NO STARTS if left sitting for several weeks or more than a month. And if you leave your Dimmer switch all the way CLOCKWISE (I have done it all) ![]() ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-21-2014 at 01:48 PM. |
#29 |
![]() Join Date: Apr 2013
I got a DieHard one at Sears a couple months ago for like $25. It is a combo charger/tender and so far it seems to work well. Hooks to the battery terminals. Car sat for a couple months in my cold garage without running - jumped in it the other day to move it so I could put crack sealer in the cracks in my garage floor, and it started right up like always. Don't know anything about the amps or any of that stuff - but it charges the batt til it's full and then goes into maintain mode. Works for me....
#30 | |
![]() Join Date: Jan 2009
![]() It is some sort of antique device that used to be used for something or other. ![]() I cut off the alligator clips on the tender and put on a male plug end. I hook my battery tender through there. No messing with attaching to the battery or alligator clips or corrosive battery acid. When I plug it in, I wrap the cord around the shift knob so there's no way I can forget to unplug it when I leave. Then I just toss it out the passenger window onto a semi soft landing area. Quick and easy.
