02-03-2014 | #11 |
Re: Fun winter project
I will update as I can and as I do things
the Rom has a Apollo Music player as part of CyanogenMod ROM (with the USB ROM stuff) I will look at Poweramp as well as Mortplayer Whatever player I choose I want to to read display the folder structure or close to it, I already have Car Home Ultra which I like and might use, I just need to get it to be the actual home screen, I also use Nova Launcher on my phone and other tablet which I could use as well ( and using for testing) For maps I will Check out Sygic as well as NavFree. does Sygic store maps locally? I tested a USB drive last night and it confirmed my thoughts that the 12-5v converter I have is not enough so I need to order a better converter/supply. Depending on time/temp this week I am hoping to finalize my mounting solution then I can work on fitting all the equipment in the car, I am also waiting on the volume/gain knob and a noise filter which I have read in several threads is needed. I also need a couple USB Extensions.. one for my USB drive and one for the phone. Here is a picture with Car Home Ultra (fed from my Phone to the App Radio I had in there:
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
02-03-2014 | #12 |
Sygic uses local maps, so you don't need to have a data connection to navigate. I'll take a look at Car Home Ultra, I haven't heard of that one, it looks similar to Car Dashboard.
I like Poweramp because you can set it to play everything at random and not forced to choose artist etc. plus you can shuffle back and forward with a swipe. Dave
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
02-03-2014 | #13 | |
02-03-2014 | #14 |
this head unit my be a good alternative option
http://www.parrot.com/usa/products/a...asteroid-smart |
02-03-2014 | #15 | |
I have the App Radio 2.. the tablet route made more sense to me and it seems to fit well
02-03-2014 | #16 |
Poweramp will organize by artist, album and genre - might do more I tend to organize my music myself into folders though. You can also import/create playlists.
02-04-2014 | #17 |
Dave, I use Pioneer Mixtrax. Power amp looks very similar with the added option of creating my own playlist.
Robert J. DeMarco [SIGPIC][/SIGPIC] [COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member NCM Lifetime Member #2655 Pacecar Registry Member [COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR] [COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR] [COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR] 1991 Callaway Aerobody ZR-1, DRM 500 1991 Shinoda Aerobody Spyder, 1998 Pace Car |
02-04-2014 | #18 |
The problem I see with the Parrot systems is that they're a very old version of Android and also you don't get full access to the Play store. Both of which are likely to limit the apps you can get and install easily.
Robert - I haven't seen mixtrax before, it looks interesting so I might try it out. Thanks. Dave
02-04-2014 | #19 |
Order a DCDC-USB power supply yesterday, it will handle up to 8A. That should cover the tablet, DAC and USB Drive
02-04-2014 | #20 | |
Definitely cool!
Custom tunes are cool too. Had a little to do with why I did the Front Panel Interface for the Bose. But if I was to put in a TV (or ANYthing with a big LED display), it would have to be capable of integrating readouts for engine - oil pressure, RPM's, voltage, vacuum, coolant temp, etc., ... An open source application would definitely be in order. Does Nexus 7 have programmability of any sort? VCR (voice character recognition)? Quote:
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] |
