#11 | |
![]() Join Date: May 2010
You are very welcome and you won't be disappointed with Skene Design; it is so adjustable too and you can even move it lower than in my photos. Best wishes, Craig
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() Last edited by HAWAIIZR-1; 02-18-2014 at 03:40 AM. |
#12 |
If my '90 had the original body, instead of the later body, I'd have integrated scoops like the Active Suspension car. Maybe off of an old F/B Formula.
Then an A/O intake could be routed through there... ![]() Last edited by Schrade; 02-19-2014 at 03:03 PM. |
#13 |
![]() Join Date: Jan 2004
Someone ought to make a 90 degree rotating plate housing, it could work like the muffler butterfly assemblies on the Z06 and rotate the plate sideways when in performance mode.
#14 |
![]() Join Date: Oct 2013
#15 |
#16 | |
Yep, there are several of these on the market but I've never seen one mounted in the factory Corvette lp hole, not sure if it would fit or not.
#17 |
No front plate? Maybe you should look again officer lol
#18 |
