Old 02-13-2014   #41
carter200
carter200's Avatar
Default Re: Carter, new part,I think.
Cliff,
Paypal payment received for 2 Bypass Plugs with heat shrink clamps and 1990/1991 engraving.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 02-14-2014   #42
Default Billet Aluminum Dipstick Handle
Originally Posted by carter200 View Post
Cliff,
Your dip stick handle is on the list but has a few customers ahead of it. Hang in there
I would think the Billet Aluminum Dipstick Handle would be of interest
a. The original plastic is often cracked and hard to see.
b. The original plastic handle is easy to remove from the metal dip stick with a hammer
c. The New Carter Billet Dipstick Handle can be easily attached to existing metal dip stick.
d. The New Carter Billet Dipstick Handle can have etched the exact engine oil used.
e. The original Dipsticks are hard to find if a replacement is needed.
f. The New Carter Billet Dipstick Handle would be easy to see and match other Carter Bling.
g. If you change your mind on the etching, just get another Billet Aluminum Dipstick Handle and replace.
h. And Last but Not Least.......there might be lots of LT5 Dipsticks available that have otherwise been discarded because the original Plastic Handles are cracked.
And Carter.....TO MAKE SURE YOU DO NOT FORGET
AMSOIL 10W-40 Etched in Red Letters on the Billet Aluminum Dipstick Handle.
See Item #3 LT5 Lubrication Tricks
Old 02-15-2014   #43
carter200
carter200's Avatar
Default Re: Pricing for Bypass Plug
The Bypass Plug pricing is as follows:
Bypass Plug - $20 shipped
Bypass plug with Heat shrink hose clamp - $25 shipped
Bypass Plug engraving is additional $8 - $10 (depending on engraving)
PM or email me for payment info.
Thanks and appreciate you support, Carter200 (CT Machining)
Nobody is interested in this????
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 02-16-2014   #44
Default TB Coolant flow Bypass Plug and Air Locked Water Pump
A few of us Block Off TB Coolant. Most of those that do Block Off TB Coolant Bypass TB Coolant using the TB Heat Bypass Line made by Marc Haibeck or similar hose that accomplishes the Coolant Bypass of the TB. This leaves the Coolant flow to the Coolant overflow tank in front of the passenger side Intact. This reduces the fear of an Air Locked Water Pump.
That leaves only a very small handful (less than a handful actually) that blocked Off TB Coolant as well as Plenum Coolant (Top of Injector Housing Coolant Port). A Total of six Allen Head 1/8 inch pipe plugs are used. The Coolant Flow Path through the Plenum has nothing to do with Cooling the Plenum but only a route for Coolant to/from the TB and a vent for the air trapped in the Injector Housing Coolant Manifolds and Water Pump. And.........that coolant flow through the TB has nothing to do with cooling the TB but rather heating the TB. Only this very small handful of ZR1 owners would need the Coolant Bypass Plug described herein.
I have experimented with the Air Locked Water Pump and have found a fool proof way of eliminating that issue once and for all. My Plenum can come off at any time in minutes with NO Coolant draining or spilled. But I digress here
Old 02-24-2014   #45
efnfast
I'm surprised this wasn't a bigger hit.
Old 02-25-2014   #46
carter200
carter200's Avatar
I just finished the Bypass Plug for efnfast. In the mail to him tomorrow and hopefully he'll post up a pic before and after. Working on front sway bar relocation brackets, LT5 rear bumper plate, billet throttle line brackets then a project for GC.
Finished the front sway bar relocation brackets and the LT5 rear bumper plate (painting it tonight) and will start on the billet throttle lines brackets next.
GC, We're getting close to your items
I have a few of the Pypass Plugs done and ready for mailing when you guys are ready for the bling
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 02-25-2014   #47
USAZR1
USAZR1's Avatar
Finished the LT5 rear bumper plate (painting it tonight)
Can you tell us more about this item,Carter?
USAZR1 is offline   Reply With Quote
Old 02-25-2014   #48
efnfast
Yeah, yeah!!
Old 02-25-2014   #49
carter200
carter200's Avatar
I'll post a pic of it tomorrow. It is the same size as the zr-1 bumper emblem and the LT5 and the bowtie are also the same size. I was asked to make one and did. Painting in the engraving tonight then I'll take some pics and see if I can get it posted so you can see.
Thanks for asking, Carter
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 02-25-2014   #50
USAZR1
USAZR1's Avatar
Did you make some for Dennis Derr? I saw those on his 93 ZR-1 and liked the look.
