Old 04-03-2014   #81
Default Re: Secondchance - 380 build begins!
Originally Posted by USAZR1 View Post
Yun,what did you use for con rods & pistons?
I believe 5.85" Eagle rods and 4" Diamond pistons. Flying Ryan and Rick Watters of Rick Watter's Racing Engine ordered pistons and rods. I don't know enough to select and match pistons, rods, rings etc...
Rick Watter's also handled crankshaft regrind with their choice of machine shop.
Old 04-03-2014   #82
Jagdpanzer
Jagdpanzer's Avatar
Looks like with the 2.000" rod journals he didn't have to notch the block to clear the rod bolts like I had to.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 04-03-2014   #83
I have to put my foot down. That's PORN on our forum.
Please take it down immediately and email it directly to me!!!!
Old 04-03-2014   #84
Lloyd commented that all fit real good and he liked the choice of parts. He said the mains were sticking at first so he had to work the main bearings a bit.
David,
Thanks for the compliment.
Old 04-03-2014   #85
Scrrem
Scrrem's Avatar
David,
That's what has me really worried with my build, this is the second build that I have seen that have encountered this issue.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 04-03-2014   #86
I am clueless how sticking mains can be fixed. I can ask and find out.
Although I don't know enough to assemble the motor, it's a real treat to be able to stop by, take pics and see it being assembled.
Old 04-03-2014   #87
Polo-1
The aluminum block and girdle move around a bit. This just happens on the LT5. Kind of scary the first time around. Every bolt needs to be torqued on the whole bottom end before turning the crank.
Nice part of the 380's (3.750 stroke) no block work needed, even with the big 2.100 stock rods
Old 04-03-2014   #88
Scrrem
Scrrem's Avatar
Good to know, I was thinking you shouldn't need to torque all the griddle skirt bolts.....Thanks for the great tip!!
Rich
Ron Davis Radiator
Old 04-03-2014   #89
I took my block back twice.....every time I torqued it the crank would stick like an SOB......6K miles later no issues. A lot of it is the engine flexing on the stand....no worries!!!
Old 04-03-2014   #90
No PORN for you! Come back three years (Soup Nazi)
