Old 04-20-2014   #11
Pat Cooke
Default Re: ROUGH RUNNING 3
Originally Posted by LantanaTX View Post
I had a similar issue and it turned out to be two issues, bad injectors and one bad coil. Injectors in 90-92 are a big problem over here caused by Ethenol added to our fuel. Are they adding Ethonol over there? If so might be time for injectors. Any type of alcolhol will destroy your injectors. I replaced with FIC injectors. Here is a good read:
http://zr1specialist.com/HAT%20Web/a...eplacement.pdf
Thanks for comments and article, very helpful !
Pat
Pat Cooke is offline   Reply With Quote
Old 10-23-2014   #12
Originally Posted by Pat Cooke View Post
My rough running now seems to be cured, I fitted reconditioned injectors and that did the
trick. Many thanks to all who advised. What a Motor !!!!
Pat
Tally Ho Pat!😄
Old 10-23-2014   #13
Pat Cooke
Smile Re: ROUGH RUNNING 3
My rough running is now cured, I changed the injectors for a reconditioned set
and that did the the trick. What a motor !!!
Pat
