#21 |
![]() Join Date: Sep 2013
Im still trying to find a factory set to NCRS my car. Steve offered me his to use, but I would rather purchase a set to have with the car.
It's the only Item I need to make my car Original, but like my old man says their only original once! |
#22 |
![]() Join Date: Oct 2013
What exactly are you looking for? I'll try to keep an eye out for it.
#23 |
#24 |
![]() Join Date: Jan 2009
I've got one from a 1991. Are they the same?
Jep |
#25 |
#26 |
Anyone with PE pipes think that the exhaust controllers at the end of the pipes can be remotely controlled? Jeff? Dave?
Electronically or by vacuum? |
#27 | |
Found this on the capsule itself! http://www.powereffects.com/tech.htm Jeff Last edited by Shrek; 02-16-2014 at 11:13 AM. |
#28 |
Spent :30 minutes getting 2 ex manifold bolts loose P side. Wow.
I found 2 ex manifold bolts missing on the 4-hole. This is looking like a BIG job... |
#29 | |
I will say while mine was on the lift a couple of months back, it appeared the header swap would not be a simple job. You can do it though, I have confidence in you Pal! |
#30 |
![]() Join Date: Feb 2010
Schrade
I just went through this. I certainly didn’t document the installation up to your standards though. Many of the bolts are accessible easiest from under the car with long extensions. Have a good assortment of extensions, swivels, swivel wrenches and short stubby combo wrenches. I used my ΒΌ “socket set on most bolts as mine were not that tight or corroded. The Passenger side is easiest. DR side a bit more difficult. I had to loosen the heat shield and bend it a bit on the DR side to get all the bolts off. New Header installation is much easier. Order a new dipstick tube gasket from Jerry if you haven’t already. My SW headers required that I make a dipstick relocation bracket. (I copied the basic design of Pauls bracket…. Thanks Paul!) I would bet your OBX headers will need it also. If you or anyone else needs to reinstall the AIR tubes on your headers, I have a stick of 304 – 3/8 OD Stainless tube that I have left over from my installation. What a bit@# to bend. Good Luck Darby |
