Old 07-24-2014   #11
Z06scentair
Z06scentair's Avatar
Default Re: Sputtering
Have you checked the plugs yet for Tracking as Joe described?
Keep us posted as to your outcome.
Old 07-24-2014   #12
Schrade
Loy's of problems can 'hide' under high rpms.
Old 08-02-2014   #13
TomZR1
Ok changed plugs, fuel filter, put new fuel and still sputters. Drove 5 miles with new fuel don't know if that's enough time to mix in.
TomZR1 is offline   Reply With Quote
Old 08-02-2014   #14
Z06scentair
New DIS installed as well?
Old 08-02-2014   #15
TomZR1
If you mean distributer cap,no. Taking off plenum looks like a nightmare?
Old 08-02-2014   #16
I thought the same thing but once you get into it, it isn't that hard. drain some coolant, 10 bolts, some connectors and you're there. the zr-1 doesn't have a distributer cap.
Old 08-02-2014   #17
TomZR1
What's (Dis)? What does it have?
Old 08-02-2014   #18
Me thinks there are 12 bolts
Removing Plenum (including the 10 minute Plenum Removal)
Old 08-02-2014   #19
TomZR1
Ok they have coils,is there a way to check if there bad? It almost seems it cuts out while sputtering.
Old 08-02-2014   #20
theres one in every crowd
