Old 08-03-2014   #1
Z06scentair
Z06scentair's Avatar
Default Re: Sputtering
Tom,
Have you pulled the plenum yet?
Can you verify all injectors have been changed?
Don't worry about the DIS yet. When I posted that last-night I was thinking about another thread, and posted on yours. My apologies!
Did you check for spark tracking on the plugs?
Brad
Old 08-03-2014   #2
The kicker is the fact this started all of a sudden.......
Did anyone mention the MAP connection yet?
Manifold Absolute Pressure Sensor (MAP)
MAP Sensor Hose Fix TIPS
MAP sensor hose disconnected
x2 on the DIS for later.
Originally Posted by Z06scentair View Post
Tom,
Brad
Old 08-03-2014   #3
TomZR1
No haven't pulled plenum,no tracking on plugs,injectors have been changed. I'm leaning towards coil,will do test with timming light test on wires & pull plug and check spark color. But before that will check fuel pressure,will keep you posted
TomZR1 is offline   Reply With Quote
Old 08-04-2014   #4
TomZR1
Ok did a fuel pressure test full throttle 49-50,I assume that's good. Next I'm going to remove plenum and test coil pck
Old 08-04-2014   #5
TomZR1
Loosened this bolts on the Plenum and radiator fluid is starting to come out is there a hose to remove the radiator fluid before I take the Bolts out?
