View Poll Results: Which oil filter do you use? | |||
AC Delco |
69 | 27.27% |
Amsoil |
1 | 0.40% |
Baldwin |
0 | 0% |
Bosch |
68 | 26.88% |
Fram |
13 | 5.14% |
K&N |
13 | 5.14% |
Mobil 1 |
54 | 21.34% |
Napa |
12 | 4.74% |
Penske |
0 | 0% |
Pennzoil |
1 | 0.40% |
PowerFlo |
1 | 0.40% |
ProLine |
0 | 0% |
Purolator |
3 | 1.19% |
Quaker State |
0 | 0% |
STP |
0 | 0% |
Wix |
18 | 7.11% |
Voters: 253. You may not vote on this poll |
Thread Tools | Display Modes |
#41 |
![]() Join Date: Dec 2012
I just bought two of the Napa 1324 Wix filters yesterday for my future oil changes. They looked them up and their data said they have the check valve as reported and a 16 pound bypass pressure. Most of the things I've bought from Napa are reasonable performers for the l48 1976's engine and now this one. Followed Marc's rec.
#42 |
Isn't this mill (LT5) bulletproof?
Seems that if you do the oil & filter change every 3k, or 3 months, whichever comes FIRST , then even a budget filter will get the job done... (unless the hammer stays on the floor for track use). I owned a fleet for courier & delivery that I ran, and did the O/C about every 10 days for all of them, for many years, which was roughly, 3k, and all the vehicles kept a good squeeze under the heads. The last one, an Express 1-ton 5.7 bought new '02 as my own personal, had ZERO squeeze loss @ 205k... |
#43 |
just out of curiosity when you reset the oil change on the dashboard, how many miles before it comes on saying to change? My 2008 TBSS calculates oil wear so it's not miles at all. How does this one work, straight miles or sensors inputs for varied use?
Manual did not say as far as I can tell. Lance |
#44 | |
![]() Join Date: Jan 2009
Page 0B-2 Figure 1 Item # 1
#45 |
I use the AC PF970 with oil change every 2000 miles.
#46 |
![]() Join Date: Nov 2007
Every 2000 miles on an oil change? Is that something you do once in the spring/start of the new driving season as a matter of routine, or ??? Just curious why the cadence is so high. Even in the DINO OIL days, 3000 miles was the norm, and that was with a 5 quart oil pan; including the filter. With full synthetic it is much higher - e.g., 5k and then some, depending on application.
#47 | |
The oil changes pretty much coincide w the driving season. I always change the oil for the winter. When I am getting ready for a long drive and/or racing situation as in going to BG, I change the oil prior to that event. The Castrol GTX I use is not SYNTH oil. I usually throw in 8-9 quarts/change w filter. |
#48 |
![]() Join Date: Dec 2003
"We also found that the NAPA 1324 filter retains eight ounces of oil after the engine is off for 24 hours. The filter is white in color and is made by WIX."
The above is from the H site oil filter recommendations page - Color is off but this is the one I use. Good price as well. |
#49 | |
![]() Join Date: Mar 2004
#50 |
![]() Join Date: Apr 2013
ACDELCO
Dr. Pete "Frankenstein's" Ported and Polish combo Cam retiming & Chip Tune Corsa Exhaust No Cat SW Stainless Long Tube Headers MSD Coils DRM Coil Overs Hurst Shifter ZF Doc Beam Plates Center Force Dual Friction |
