Old 07-26-2007   #12
8upZR1
8upZR1's Avatar
Default Re: A serious problem
I have two ECU's and three chips but no combo seems to solve the issue. There are some noticeable driving differences between the chips as there should be but nothing significant. I drove a little with the pins jumped and it didn't make a difference. I am going to look into one of these scanners. Maybe that will lead to some insight. I did a quick diagnostic with a voltmeter of the ignition module test port and everything seems ok. An oscilloscope would probably be the better test equipment but I do not have one. The Ref high, ref low, EST out, tach out, bypass line all look good before and after cranking.
