Go Back   ZR-1 Net Registry Forums > Off Topic > OFF TOPIC
Old 05-04-2015   #11
Z06scentair
Z06scentair's Avatar
Default Re: Road trip: drive it or drag it?
Under no circumstance drive the car if you can transport....keep the miles as low as possible.
It's one thing to get wet on the topside, the bottom side is a different story.
Once they have been on wet roads it becomes nearly impossible to rid the evidence.
The true collector would be looking for that residual grime if for some reason you decide to part with it in the future.
Beautiful Car.......preserve it for what it is!
Old 05-05-2015   #12
BigJohn
BigJohn's Avatar
Funny, I drive and enjoy all 17 of my cars. Low mileage often means major problems to a collector.
BigJohn is online now   Reply With Quote
Old 05-05-2015   #13
Z06scentair
Sounds like a nice collection you have, and drive them as you wish.
Tell more about your collection?
Brad
Old 05-05-2015   #14
GTOger
We ultimately decided to drag the car on the trailer. Nowhere near as fun as driving it, but this did afford us the protection from a faulty fuel level sending unit (stuck on full) as well as the occasional stall we've gotten coming down from highway speeds. Some detergent will fix the fuel level sender, and Corey is working on the tune to see if we can get rid of the seemingly random stall.
We'll roll out with everything except the ZR-1 in a couple days. The list on the ZR-1 keeps growing. Eeek!
GTOger is offline   Reply With Quote
Old 05-11-2015   #15
GTOger
In case anyone wants to hear what an old pushrod Firehawk from the early 90's sounds like on the HPT dyno...
https://youtu.be/lCHdhw9A2Pc?t=36s
FWIW, we ran a calculated 320 HP & 404 LB FT at the flywheel, which seems a bit low on the HP and a bit high on the torque if you compare to what the manufacturer advertised. That said, it still feels like an absolute kick in the pants to stomp on it. So that's satisfying.
Old 06-22-2015   #16
Fully Vetted
Fully Vetted's Avatar
Corey does such good work. We are lucky to have him.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 06-22-2015   #17
GTOger
OMG, yes. I'm not sure if "lucky" rises to the level to adequately express my appreciation for his expertise, time, and workmanship.
That said.. I *am* starting to miss my beast. I'm getting quite anxious to take it for a ride. I understand that a lot of people can get through a week without the rush of some V8 thrust. I just don't know how they do it.
Old 06-22-2015   #18
Fully Vetted
If you need a ride down let me know when it's ready. If I'm not too tied up I'll take you. I could use a break.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
