Old 05-25-2015   #1
Default Re: Oil leak help...
Originally Posted by bans25 View Post
Oil leak on pass side of the block I think it may be this sensor near oil dipstick? Any idea what this sensor is? Does this typically leak oil or probable it's something else leaking? I have about 40k miles on my 90.
Thanks much!
A bit more information on exactly where the oil is "dripping" from and how much?
Is the oil dripping from the side of the oil pan and between what two oil pan bolts?
One method to use is to pressure wash the under side of the engine including from top right and left side (under hood) just below cam covers (when engine is NOT hot). Do not get water below the Plenum in the Valley. After the pressure wash it is then much easier to see fresh oil leaks.
