Old 06-29-2015   #1
johnboy89
Default Raising Front
I'm looking to get my front up a bit, front is slammed way down (done by previous owner).
I believe it has the Wedge kit in it, what I don't know is if the factory shims have been removed, my guess is they have.
So going forward should I just re-install factory shims and see what the ride height is like? I wouldn't be against putting it back to stock ride height either. If so are these shims/rubber bushings still available?
Thanx
johnboy89 is offline   Reply With Quote
Old 06-29-2015   #2
JimZRyd
JimZRyd's Avatar
Default Re: Raising Front
Is your rear lowered as well? I'm in the process of putting coilovers on my 94. Finishing up the rear and will be moving on to the front this week. I could check it out and send you some pics of a stock set up if you like.
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 06-29-2015   #3
mike100
The rubber bushings are cut off when the lowering wedges are installed. Putting both shims on top of the spring does help to raise it 3/8 of an inch or so. I have previously mulled over how to machine a delrin or hard rubber bushing of sorts to restore the use of previously altered springs (since there are so many of them with the wedge hack mod), but i've never actually tried it. In two cases I was able to find replacement springs.
Old 06-30-2015   #4
johnboy89
I'm going to have to jack the car up, looking last night on the lower control arm, appears the rubber bushing is still there? I don't see any wedges either? Are they not visible from the top?
Old 06-30-2015   #5
I need to pm you about and unrelated issue. Just posting to remind myself
Old 06-30-2015   #6
batchman
They are underneath, flanking the oil pan, about 18" apart or so IIRC.
HTH,
- Jeff
Old 06-30-2015   #7
mike100
you can see the main rubber spring mounts in the center of the spring. There are also rubber pads on the end that should be present. The middle ones are trimmed down to alter the mounting height and preload of the spring (basically letting it un-arch itself for a softer preload). This results in the car dropping down. Further preload is increased by adding aluminum shims to the top of the spring bushing which pushes the center down even farther increasing the initial tension (raising car). Different models have different spacer depending on desired ride height and vehicle weight and spring type. Convertibles have 2 shims for the extra ground clearance, ZR-1's have 2 due to the weight of the LT5 (best I can figure). Other models have a single shim.
Not shown here, but the other side of the rubber bushings are completely removed- I was changing this spring for stock that I traded for.
Here you can see the shims removed and mounted on the bottom (just going along for the ride- nice of the last owner to have not thrown them away- they are normally on top of the bushing pack)
Old 07-01-2015   #8
batchman
Thanks for posting that pic, Mike - but I have a question for you. Is the jack supporting something engine-wise allowing removal of the diagonal brace? I have to do my LCA bushings and while I gather pulling that is not a problem on a regular 350, I was not so sure about LT5...
Thanks,
- Jeff
Old 07-01-2015   #9
mike100
The jack was just there to get the car up extra high due to the heavy arch in the stock spring...just allows enough space to twist it out of there. The diagonal crossbeams come right out on all C4's as the actual motor mount tab is welded to the frame...the supports are just extra triangulation that is removable.
Old 07-03-2015   #10
johnboy89
This helped Mike, but other than getting a stock spring is there anything I can do do bump it up.
Thanx
