#31 | |
![]() Join Date: Dec 2003
Yes sir, plus shipping but in your case no shipping i can hand them to you. ![]() Pete
#32 |
![]() Join Date: Jul 2007
okay, just checking, unfortunately I am not ready for those yet
#33 |
Hi Pete,
I'd have seen this sooner (like, last time around) if it was in the FS section. 2 Qs if you will, #1 how much weight are we talking about? I haven't had either of these off the car. #2 how much underdrive on the WP, and will it still cool at idle on a hot day? Thanks much, glad I saw this. I don't get by here like I used too (been busy). Best, - Jeff |
#34 | |
Stock Water Pump 28.3 oz Aluminum WP 14.3 oz Stock Power Steering 30.5 oz Aluminum PS 20.5 The Water Pump Underdrive Pulley is 10% I have not done real world test but there are a few ZR-1's out there with the UD WP pulley's i haven't had any bad feedback. Pete
#35 |
I have Pete's P/S pulley, WP pulley, and Alternator under drive pulleys. They all work fine. I don't even suspect that they are on there.
#36 |
![]() Join Date: Aug 2013
Did someone have pictures?
#37 |
![]() Join Date: Nov 2011
I have a thought about under drive on the water pump. I know they cavitate at high speed, but at low speed is the pump moving enough water to cool the engine. Maybe over heating at low speed is not an air flow issue, but a water flow issue. If this goes anywhere, it may warrent a new thread. Sorry Pete, didn't mean to side track the thread.
#38 | |
![]() Join Date: Oct 2004
I'd think "all is well".. |
#39 | |
There are existing threads including technical discussions of both situations and options (Air Flow through the radiator and water Pump Cavitation). The Air Flow discussions include options related to higher flow rate Cooling Fans. The Water Pump discussions include Under Drive Pulleys and electrical driven Water Pumps (driven by lower speed electrical motors vice the serpentine belt at very high engine rpms). Thermostat opening temperatures are also discussed as that relates to Engine Cooling. Other issues discussed in these related threads include the Cooling Stack which consists of the Engine Cooling Radiator, Engine Oil Cooler, and ZR-1 Interior Cooling (AC Condenser). These related discussions also include the Engine Coolant Thermostat Options. There are several Aluminum Radiator Options that DO offer better engine Cooling in traffic at slow speeds or when idling at stop lights. I can find the various threads and technical discussions related to Engine Cooling and post here as desired. ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-21-2015 at 09:18 AM. |
#40 |
Soooo Cliff, how do the guys with electric water pumps do in traffic. Electric pumps are not engine speed dependent.
