Old 11-01-2015   #1
BigIke
Default Request - Master Cylinder Push Rod Diameter
Hey guys, the ZR-1 is still on the lift. Installing the RAM conversion we observed that the slave cylinder fittings make contact with the pressure plate. So I need to limit travel.
I'm going to limit travel at the MC push rod by installing a split-clamp on the rod. Just need the diameter so I order the right part.
I'm waiting on a few parts to complete assembly so I won't be near the car for the next few days.
Thanks for your time,
Jay
BigIke is offline   Reply With Quote
Old 11-01-2015   #2
Corvettes White
Default Re: Request - Master Cylinder Push Rod Diameter
0.291" dia. Part with reservoir. Not sure that is what you were asking for. George
Old 11-01-2015   #3
BigIke
That's it, the MC push rod. Thanks, going to try and put a small split clamp around the shaft near the eye to limit hydraulic release bearing (HBR) travel.
Got a 7mm steel and a 1/4" teflon split clamp.
Thanks again,
Jay
Old 11-01-2015   #4
Corvettes White
Welcome.
