Old 07-20-2016   #9
steve1263
Default Re: Chmsl fixed but now...
The switch just needs be be adjusted then the brake lights will then work properly I had the same problem when i replaced the switch in my 91. If i remember correctly there are 2 wires to the switch, one is for the brake lights and the other is for the cruise control some replacement switches only have one connector, check to make sure you have the proper switch and that both wires are connected.
steve1263 is offline   Reply With Quote
