Old 09-02-2016   #1
KJL
Default 90 degree adaptor for Fuel Pressure Test Hose
Trying to get my hose on the fuel rail schrader valve is a PITA. I was wondering if anyone knows of a 90 degree fitting that will screw into the test hose and over the fuel rail valve? All I can find are 90 degree fittings with a quick disconnect on the test hose side.
1995 ZR1 #159
Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp
1992 ZR1 #280
Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp
1996 Collectors LT4 (Stock)
1972 Convertible 434 Small Block
572 rwhp
KJL is offline   Reply With Quote
Old 09-02-2016   #2
RussMcB
Default Re: 90 degree adaptor for Fuel Pressure Test Hose
This is from memory so may not be accurate - I think it is a standard thread (something like 3/8-24 or AN-6. I had a fitting that fit, and I was able to cobble together a pressure tester. I think I temporarily removed the inner Schrader valve during the test.
I'll probably be around on Saturday if you want me to check to see if I have something you can borrow.
Old 09-02-2016   #3
KJL
I was looking for an adapter to keep on hand. I guess if the valve is removed for testing, that would open up some possibilities. I have of bunch of misc. fittings I will try. Thanks for the idea!
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 09-02-2016   #4
BigJohn
BigJohn's Avatar
Replacement Bicycle Pump Head?
Old 09-02-2016   #5
KJL
Thread size is not big enough.
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
Old 09-02-2016   #6
check nitrous fittings for fuel rails.....or speed shop
Old 09-02-2016   #7
WVZR-1
GM & standard Schrader I'm quite sure is .305 - 32 TPI (sometimes .302 is mentioned also and that I believe comes from a Metric conversion).
BUT this ain't correct for FI Schrader external. I believe the terminology for the FI Schrader is just "large Schrader".
Old 09-02-2016   #8
Never thought of trying but a TSV-01 might work:
https://www.topeak.com/global/en/pro...-valve-adapter
You never cease to amaze me with your infinite wealth of knowledge.
Old 09-02-2016   #9
That makes 2 of us
Old 09-02-2016   #10
3 of us
I was going to try the AC connectors
