Old 01-09-2017   #11
mike100
Default Re: 1991 ZR-1 42k miles
The catalyst to selling this car was when I had to take my headers off to pass the emissions testing here. So disappointed with the drop in power... although the lower noise level is a plus with the oem manifolds.
I'm kind of committed to staying in CA for a few more years so I'm leaning towards EV's. Already solared up my house and bought a Volt.
Old 01-09-2017   #12
lfalzarano
EV's don't provide the smell and sound of a fossil fueled LT5.
CA won't accept headers with CAT's attached?
Old 01-09-2017   #13
Hog
I have been told that any long tube headers will not pass, and any setup that modifies the distance from the engine to the catalyst.
Old 01-09-2017   #14
lfalzarano
When you retire, move from that anti-RealCar state.
Old 01-09-2017   #15
HAWAIIZR-1's Avatar
GLWS. I guess if I were still in CA my plan to get under the radar of smog Nazis would not have worked?
I had Marc modify short tubes with AIR and I also modified C6 Z06 cats to bolt on as you recommended. I'll install it here as soon as I have time.
Best wishes whichever way you go.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 01-09-2017   #16
mike100
Drop the $2000 so you'll keep it. Hate to see you sell it and leave the family. What would you replace it with? As long as no regrets, it's all good. But that is one nice ride you have there.
If I ever do a second LT5 car, I'd lean toward getting one that was pretty well fixed up. Not sure I have enough motivation to rebuild a steering column, replace the injectors, port the injector housings, C5 convert the brakes, redo a bunch of driveline stuff, rebuild the shocks, replace a bunch of standard service items, and chase down the oil leaks all over again.
On the other hand, if a worthy buyer comes with an agreeable offer, then I would pass it along.
Old 01-09-2017   #17
mike100
ZRDon in Temecula had made that, but had to use the replacement LT1 catalyst that is listed on the certified replacement roster. In actual practice, that might have passed visual, but technically you are supposed to appeal to the referee to prove that the oem manifold is no longer available and that your homebuilt shorties are what you are going to run.
Old 01-09-2017   #18
HAWAIIZR-1's Avatar
Thanks for the explanation and best wishes. Sorry to pollute your ad. We'll miss you if you sell, but surely understood.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 01-10-2017   #19
S52MC
Clean car and one I considered, but the timing isn't right. Have you considered putting this on Bring a Trailer? Should provide a much broader audience.
S52MC is offline   Reply With Quote
Old 01-10-2017   #20
Vette73
Since the car is now over 25 years old isn't smog testing out the window? In NY it's only a safety inspection.....No more smog testing.....All the performance cars I have owned in the past never passed inspection.....Allthough my mechanic always got me a sticker, no questions asked....
