Old 02-09-2017   #10
steve1263
Default Re: LED headlight upgrade
That is exactly what it does. When I was installing the led headlights on my car I turned on the lights after the first one was in and found everything working properly including the fog lights. when I installed the second light and tested everything I noticed the fog light problem. The resistor is advertised as a fix for the bulb out problem some cars experience when converting to leds. Both problems are addressed by simulating the load of an normal bulb, thats why you only need one.
steve1263 is offline
