Old 11-20-2007   #1
32valvZ
32valvZ's Avatar
Default couple a quick ?'s
First, why does my LTPWS light come on everytime I drive for a little while? I dont have any air loss in any tire.
Second, does anyone know a part number for the reverse light switch on the ZF.........I assume it would be the same as a regular C4 with the ZF, but I want to double check that.
TIA
Old 11-20-2007   #2
Jeffvette
Default Re: couple a quick ?'s
LTPWS is garbage. My suggestion is to pull them out as they are a hazard when driving at speed. But more than likely the power generator is going out on it.
Back up light is #10159402
Old 11-20-2007   #3
32valvZ
32valvZ's Avatar
just to reiterate...this is the switch on the tranny...not a light correct?
Old 11-20-2007   #4
Jeffvette
Correct, it's a pain to get out.
Old 11-20-2007   #5
32valvZ
32valvZ's Avatar
Ok, thanks Jeff...yea, it will be a tight area to fit a wrench in, but I think I can get to it......I can always "manipulate" one of my old non Snap-On wrenches to fit up there or an old socket. It almost looks like if I were to take a drift and tap it with a hammer, I could break off the plastic enough to easily get a socket to fit in there with a small breaker bar.....
Should I expect my local GM dealer to have this?
Old 11-20-2007   #6
Jeffvette
I would not expect them to. The Reno warehouse shows 2 in stock and the LA warehouse shows 6 available.
Old 11-20-2007   #7
32valvZ
32valvZ's Avatar
Yea, I basically meant they can order it for me if I ask for that specific pt#...sorry for being unclear. thanks again....
Old 11-22-2007   #8
Aurora40
Aurora40's Avatar
FYI, I ordered the switch from Bill B, and he sent along a tool he'd fabbed up. Worked like a charm, and I shipped him the tool back along with a check.
Old 11-22-2007   #9
Jason 91
Jason 91's Avatar
I need to do the same thing to mine. What is the special tool?
Thanks,
Jason
Jason 91 is offline   Reply With Quote
Old 11-23-2007   #10
Aurora40
Aurora40's Avatar
It was just a box wrench only he like welded on another box wrench head IIRC, so it was deeper.
