Old 06-26-2017   #21
Default Re: Sooty #7
One other thought: isn't the vacuum line for the pressure regulator just about directly over the #7 plenum runner? You know where I'm going...!
I have no clue........please describe for us less familiar
Old 06-26-2017   #22
Are you thinking fuel pressure regulator leaking internally dumping excess fuel into #7 cylinder?
Old 06-26-2017   #23
I would suspect that FP would be affected whcih would show up across the board for the plugs.
Old 06-26-2017   #24
mike100
Poor man's leakdown test: What is the compression on one crank compared to other cylinders?
Old 06-27-2017   #25
Well yes the PR vacuum line is by #7 but plenum volume is supplying vacuum so its hard for me to gather how it discriminates on #7.
As I recall the Fuel Pressure Regulator last time I had one fail (someone else ZR-1) there was raw gas all the way forward coming out the Air Intake in front of Throttle Body which.........raw gas got there through the FPR vacuum line.
Yes.....I would be more suspect of the uneven compression. Blue or Black smoke for example.....burning oil or gas??
You say gray/blackish exhaust??
Old 06-27-2017   #26
I do get a gray/blackish exhaust coming out when I jump on the throttle that appears to clear out. However, no such indication at startup or steady cruise.
I'm leaning a bit more towards out of phase cams on the driver's side. That side of the motor exhibits noticeably lower compression #s than the passenger side although all with the exception of #3 appear to be within the 10% tolerance level.
