Go Back   ZR-1 Net Registry Forums > Off Topic > OFF TOPIC
Old 10-07-2017   #3
alnukem
Default Re: Input on 10 Car Storage Building?????
Originally Posted by Tripler View Post
If you can put in floor hydronic heating in the concrete base of the garage . Use solar or ground source heatpump to heat the floor . Install an air exchanger for humidity control . Try to use as much solar and battery storage to run fans and pumps and LED lighting .
If i could build a place to store vehicles that is what I would do . Try to stay off the grid ...
Sent from my LG-H831 using ZR-1 Net Registry mobile app
Thanks, Lighting is not a big issue, but I would install LED's anyway. I will look into the other things. I really wish I had gas available to me, much cheaper in my area.
