Old 10-14-2017   #11
Default Re: Bluetooth for everyone! 25$!
What happens if u r traveling and your "empty platform" isn't emptyas u travel?
I have an Pioneer AppRadio 4 in the ZR do don't need this, but I'd
like to have iPhone connectivity in my 04 Lexus.
Old 10-14-2017   #12
Yeah Dom that's what I meant by Chinese English. I read it and cracked up. It took me a while to find my non hiss station but it works pretty good. You hand tune the frequency on the app with a swipe and then manually adjusting your radio to match. It gives you a tone and then you simply connect. iTunes works well. The gadget even lets you change the color of the power light display. It also displays volts as Ike said.
Old 10-14-2017   #13
Originally Posted by RichS View Post
I ordered one to try since my CD is dead. Came yesterday but haven't had time to try it. The cassette adapter sounds horrible I already had, but the tapes sound good. I need to decide if I want to rip it all out over the winter, or get the CD fixed and add a aux input. Thanks for the heads up!
Rich the problem with upgrading and adding the AUX input is a CD still has to run to use it. So the black rubber band that rotates and continues to power even though the AUX is being used just like the Old cassette adaptors. My suggestion is this little $25 unit solves that problem vs having to pull anything. The repair and aux mod alone is very pricey. IKE has found a cheap and elegant solution. GC
Old 10-14-2017   #14
Ccmano
Does this give you hands free phone functionality?
H
Old 10-14-2017   #15
H
No it's just a FM transmitter with a lot of other functions. But it will notify you when you are receiving a call if you wish. GC
